New Product
zappy
CA.
No.
No.
I dont think there going to be that popular.You need a juction box after 4 ninties.Maybe they would be ok for straight runs.
480sparky
Iowegia
I've done plenty of jobs where you would have dozens of boxes in a straight run. 4squares aren't just for pull boxes, ya know. I also use them for light fixtures......
Long runs in corridors for lighting, fire alarm, etc. is another use.
But personally, I would never need such a tool. I put worms on the ends of all my fishtapes, and have no problems getting it to go through box after box. I don't have any pix of it, but I did 28 boxes in about 180' in a school once for either the fire alarm or speaker system (I don't recall any more) and pushed the tape from one end to the other. Pulled the cables from on end to the other, then went through and pulled loops into each box.
LarryFine
Henrico County, VA
Electrical Contractor
Interesting observations, in no particular order:
They're destroyed in removal, assuring repeat purchase.
The red ones remind me of green wirenuts and screws.
Only new ones may require trimming; used ones don't.
MF Dagger
Pig's Eye, MN
Different hooks for different folks. I bend mine like that for fishinbg in walls. you get two bent like that and kicked to the side slightly and you flip them and it catches the other. For conduit I've found that the little leader they sell is best for that.
JES2727
NJ
>> For example if you would normally quote 6 hours to snake and pull wire You can now do it in 2 hours <<
I think their labor saving estimates are a bit optimistic. We're going to save four hours on a six hour task just by pushing the snake straight through the pipe without stopping? I don't think so....
