stew
- federal way,washington
Using the new requirement now allows us to use that equipment as our service with gecs coming off that gear
Then we can locate our sub panel anywhere that works. Our state of wash used to limit the length of unfused conductors to 15 inside the structure. Now if you use a fused disconnect or breaker outside you can run any length you need to the sub
Correct. Just havent done a new construction in a good long while.
