We have a CNC mill that has a machine nameplate of 87 amps FLA three phase 480volts. Initially, I specked the following:
wire size = 1.25 x 87 = 108.75 amps = 2AWG copper
EGC = 6AWG copper
Busplug with DE fuses = 1.75 x 87 = 152.25 amps = 200 amp busplug with 175amp (rounded up to next standard size) DE fuses
1 1/2" EMT from machine to busplug (less than 50 feet)
I'm told that the busplug and dual element fuse size is incorrect by our maintenance electrician and that we can use a 100 amp busplug with 100 amp dual element fuses.
His reasoning is that the fuse size is a "maximum" at 1.75 and this should be calculated at 1.25 which still gives us 108.75 amps but we round down in size to the lower standard fuse size of 100 amps.
I have attended two code update classes and we have always used the 1.75 in the calculations for a dual element fuse.
My questions are, can we start at 1.25 and go to the maximum of 1.75 for a dual element fuse and do we round up or down for the standard fuse size?
EGC = 6AWG copper
