New service install questions
Jbaucom86
New User
NC
Hi folks, new to the forums. Bringing a 100 amp service to my new garage and just wanted to get some input. Just to give a rundown of the project, I have an existing meter base that used to feed a horse barn that is no longer used and I plan use it to feed the panel in the new garage. There will be a 100 amp main breaker just below the meter going to pvc conduit, switching to RMC before ground level, then switching back to pvc out of ground level at the garage. I will be running 3-#3 thhn and 1-#8 thhn for ground. The ground rod is located at the base of the light pole. The soil is half clay/half dirt hence the reason for RMC so I can use a min. 6" cover. To bond the RMC would I be ok with one clamp at the pole side going to the ground rod or do I need a clamp/rod at both ends? Please correct me if I'm wrong but the wire size/type should be sufficient. Also I couldn't find much information on this, but looking to use a threadless coupling on the buried RMC.
Thanks
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
