New service to a barn with disconnect
BDR
Michigan, USA
Hello,
To save costs we dropped a new meter for a 200 Amp service.
The meter and main disconnect are located 200 feet away from the barn on a unistrut mount.
There are 4 wires feeding the new 200 AMP main panel in the barn.
At the main disconnect there are two ground rods driven and the ground is bonded to the neutral with the screw.
At the barn. There are the two main feed wires and the Neutral. Plus the ground coming from the disconnect.
We drove two ground rods at the barn panel and hooked this into the Neutral Bar.
The Ground from the main disconnect we hooked to a separate ground bar.
And all grounds from the circuits will be landed on this bar.
While all neutrals would land on the neutral bar.
Does this seem correct?
