New structure over an underground lateral feed
joea
New member
Marbletown NY
Retired-ish
I have run this by the Bldg inspector and the Electrical Inspector they use.
I want to build a Garage, needing a "monolithic slab" foundation. Or something like that. The place I want to build it is over the existing main feed to the house. Not certain how deep, as yet. Dig Safe is coming out to map it, but I don't know they can tell the depth.
Initially, the EI said "no way". But after some discussion, it became a "common sense" discussion. Well, I have never been accused of having much of that. So digging a bit more on my own, came up with this (oddly enough found on this site) which seems to give me some leeway.
230.3 Pass Through a Building or Structure
Service conductors cannot pass through the interior of another building or other structure.
230.6 Conductors Considered Outside a Building. Conductors are considered outside a building when they are installed:
(1) Under not less than 2 in. of concrete beneath a building or structure.
(2) Within a building or structure in a raceway that is encased in no less than 2 in. thick of concrete or brick.
(3) Installed in a vault that meets the construction requirements of Article 450, Part III.
(4) In conduit under not less than 18 in. of earth beneath a building or structure.
Author?s Comment: Service conductors must not be installed inside a building [230-70(A)(1)], but if the raceway is below a building, the service conductors are considered outside the building. Figure 230-4 230-06(1).cdr
So, if I can clear the conduit/raceway with the foundation (vertically) would I be legal?
Thanks.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
