jesse82nc
New member
- United States
So I will be installing a new flush mounted panel in a wall for an attached garage and laundry room addition. It is a 100A panel with a 90A breaker in it. I plan to feed it from the main panel with 2-2-2-8 Cu NM by routing it through the crawlspace (the main panel is outside and the back already has a knockout into the crawlspace), then into the laundry room where the new subpanel will be located. All walls are 2x6 in the laundry room and garage for reference. I want to use a 2.5" PVC conduit from the crawlspace up inside the wall to the bottom of the panel (the main breaker will be mounted at the bottom of the panel). And then I wanted to use a 2.5" or 3" conduit from the top of the panel to the attic above for the branch circuits. I plan to use mostly 12/2 NM for the branch circuits.
My head is spinning trying to figure out Ch 9 Table 9 as to how many wires I can run within the conduits.
Can anyone answer that question?
