USACE_Nash
- Nashville, TN
Hello Everyone,
I'm looking for a little advice on determining NFPA occupancy when the building doesn't fit any of the existing types. We have a small visitor's center that is just a few restrooms and service closets so I'm not sure how to classify it. It's essentially just a comfort station; there is no lobby and the restrooms open directly to the outside. In one of the restrooms there are two service closets, one for electrical service and another for IT equipment for a display on the exterior of the building.
Initially I was going to try to classify it as an assembly occupancy as that seems the most generic but there's too many things in that section that don't make sense for our structure. Also I've searched these forums and others and with NFPA 101 questions a common answer is that the local building code should be followed. In this case we are on federal land and the AHJ has design guidance that specifically states that the building must be designed in accordance with NFPA 101.
