DCS
New member
- Painesville, OH, USA
When our technicians need to replace 120 volt devices such as temperature or pressure switches; our policy for this job is to always work de-energized. To de-energize these devices they must go to a control cabinet with 120 volt exposed live parts and pull a small swing out control fuse.
The first option of 70E is to not work energized if you don’t have to and if you must work energized you usually need a permit. However, though one would still need PPE, 70E does not require a permit for investigating, testing or troubleshooting, etc..
In this case our goal is to work de-energized downstream from this panel by pulling a little control fuse.
So, all that said, is the act of pulling this fuse so we can work de-energized, Permit Required Energized Work?
