tntsec@gmail.com
New member
- Augusta, GA USA
Does NFPA 70E mention tasks of Megger (insulation dielectric) testing or Hi Pot testing, relating the requirements for the use of Voltage Rated Gloves to install and/or remove test leads or ground leads used to discharge the test circuit? If not, what task is used to relate this testing practice and what safety protective equipment is required to perform the task?
