Nfpa 70e
zog
Charlotte, NC
Nope, OSHA just adopted the installation requirements from the 70E in August but not the safe work practices. Some of the 70E requirements are the same as the OSHA requirements but not the arc flash stuff (yet). It depends on what specific question about the 70E you are asking whether or not it is an OSHA requirement.
Either way, everything in the 70E soon will be in OSHA so you might as well be in compliance now.
EBFD6
MA
davidr43229 said:
As well as being tied back to the NEC section 110.16, via a fine print note.
Just my $.02
90.5(c) - fine print notes are for informational purposes only and are not enforceable
davidr43229
Columbus, Oh
EBFD6,
Usually you are correct. A FPN only means used as an example. This FPN (fine print note) however, became the standard since no other standard came close.
OSHA is now fining employers under the NFPA-70E as a stand-alone, rather than an abatement, meaning OSHA usually fines employers under a 1910.XXX general Duty Clause. $100,000+ is typical.
Just my $.02
