When is an Arc Flash Analysis Required: OSHA or Code Requirement?
Good question. Tough answer:
OSHA requires two basic things:
1) To keep the workplace "free from recognized hazards."
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_id=3359&p_table=OSHACT
2) To assess reasonable hazards. See OSHA's appendix. You don't have to use it BUT you must do something reasonable. (NFPA 70E would be considered a reasonable assessment with the table method and/or arc flash calculations.)
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=STANDARDS&p_id=10120
NEC (The Code)
The 2008 current version states the following:
?110.16 Flash Protection. Electrical equipment, such as switchboards, panelboards, industrial control panels, meter socket enclosures, and motor control centers, that are in other than dwelling occupancies, and are likely to require examination, adjustment, servicing, or maintenance while energized shall be field marked to warn qualified persons of potential electric arc flash hazards. The marking shall be located so as to be clearly visible to qualified persons before examination, adjustment, servicing, or maintenance of the equipment.
FPN No. 1: NFPA 70E-2004, Standard for Electrical Safety in the Workplace, provides assistance in determining severity of potential exposure, planning safe work practices, and selecting personal protective equipment.
FPN No. 2: ANSI Z535.4-1998, Product Safety Signs and Labels, provides
guidelines for the design of safety signs and labels for application to products."
So some type of labeling is required by code but not mandatory to have a specific label. FPN as all of you guys know is non-mandatory but "recommended". It is tough to argue against FPN's in a jury trial but government folks will often accept that argument. I think doing a good assesssment is key to protecting folks.
