ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.
Florida recently adopted the 8th Edition of the Florida Fire Prevention Code and the 8th Edition of the Florida Building Code, with an effective date of 12/31/2023. The referenced publications section of those codes should direct you to the applicable NFPA 72/101/96 versions as noted by Ron.
You should be getting in the habit of looking at each State's website to determine what is applicable per State. You can find a link that directs you to the 8th edition code book on the ICC website here: https://www.floridabuilding.org/bc/bc_default.aspx
