N Natfuelbilll Senior Member Jun 2, 2016 #1 Can a (down) conductor connected to a 60' flood light pole mounted lightning rod be run inside the pole?
G GoldDigger Moderator Staff member Location Placerville, CA, USA Occupation Retired PV System Designer Jun 2, 2016 #2 Natfuelbilll said: Can a (down) conductor connected to a 60' flood light pole mounted lightning rod be run inside the pole? Click to expand... Without any specific knowledge of applicable codes, I can say that it should not be inside a ferrous metal pole. If the pole is aluminum, I can't give any advice.
