I've been reading NFPA 79, getting confused!
I have a control panel containing four VFD controllers (four motors with local disconnects located out of sight of the panel). The panel has a main disconnect handle for the 480V supply. Each VFD controller has an internal mounted disconnect.
The question is, do these VFD disconnects need to be accessible from outside the panel? Currently, you can only shut them off by disconnecting the main and opening the panel door.
