drumburg
- Wisconsin, USA
Hi Gang.
I am working on trying to find out when to use enclosure interlocks and what is a decent one that I can get the most bang for my buck. I have reviewed the NFPA 79 chapters 5 & 6 and dug around here a bit on the topic and it seems that the key to whether or not an interlock is required or not is what the enclosure is used for. We build automated equipment and we always have an interlock on our systems main enclosure from the through door rotary disconnect with an NFPA 79 Compliance Kit from the disconnect manufacturer. NFPA 79 states that any control enclosure must have an interlock. What is the definition of a control enclosure? Since our main enclosure is always interlocked via the disconnect, this only comes up when we have remote boxes that house components with >50 Vac or >60 Vdc per NFPA 79 6.2.4.
Specific example, my current project is going to require a remote box hardwired to the main enclosure (no plugs or disconnect points). This remote box will have 230Vac, 3ph to run 4 motor speed controls for the conveyors on the system. The box will also house the safety contactor and the circuit breakers for those conveyors. Does this enclosure require an interlock? Does having a disconnecting plug or switch on this remote box change anything?
Thanks for you time!
