bure961
- Farmingham, MA
When 2015 nfpa 70e comes out soon will it replace 2012 automatically or is it like nec that has to be adopted by each state ? Any other method ? Thanks.
Well, there's the start of it then. So who inspects for it? The local building dept. AHJs or the Fire Marshals?NFPA70E is adopted by reference in WV as part of the state Fire and/or Building code. It is just as enforceable as NFPA 70.
The issuance of an NFPA document supersedes all previous editions, as detailed in the paragraph that precedes the foreword in the 2012 70E, where it states that the 2012 edition has an effective date of August 31, 2011.
The 70E 2015 edition will be available 10/10/14 according to the NFPA website.
I've always understood this to be a consensus safety standard, and as such, it comes into effect when issued.
But as jraef wrote, it's not enforced unless there's an incident. And then when OSHA visits, you better be meeting 70E criteria, or be able to defend the program you're following.
From what I've seen, there are significant improvements to the document, directed at more sensible management of electrical systems.
