CrazyWabbit
- Fort Worth TX
- Engr
I get it, loss of life is tragic. the risk needs to be properly quantified. so there was one occurrence of a child climbing over a fence and steps onto a AC condenser and dies, tragic; if 2 or more die per period (NFPA needs to define period) then the NFPA should consider action. but first consider if the circuit was properly wired would the death have occurred. in the case of the boy, if the AC condenser had a functioning ground the fault would have cleared and the death would not have occurred.
the loss of life/property damage under a certain occurrence should be acceptable based on the cost the rule would incur.
for example, commercial aircraft are NOT required to contain a rotor burst if the occurrence is under 10e-9 per flight. blades are required to be contained because they occur more frequently. as a result i avoid sitting in the burst zone when flying, i will leave that to the uneducated.
so should GFCI breakers be required for AC condensers and well pumps, NO. please retract this requirement.
