OSHA is the ?SHALL? comply with the law.
While OSHA tells you what to do to avoid electrical dangers, 70E tells you how.
OSHA 29 CFR
1910.132(d)(1)
The employer shall assess the workplace to determine if hazards are present, or are likely to be present, which necessitate the use of personal protective equipment (PPE). If such hazards are present, or likely to be present, the employer shall:
1910.132(d)(1)(i)
Select, and have each affected employee use, the types of PPE that will protect the affected employee from the hazards identified in the hazard assessment.
1910.132(d)(2)
The employer shall verify that the required workplace hazard assessment has been performed through a written certification that identifies the workplace evaluated; the person certifying that the evaluation has been performed; the date(s) of the hazard assessment; and, which identifies the document as a certification of hazard assessment.
Can you be cited for non compliance with 70E? Yes, in the event of a serious electrical shock or arc flash burn OSHA has issued citation for not complying with 1910.335(a)(1)(i)?employer need to indentify hazard and then need for PPE. OSHA does not tell you how to select PPE but 70E does.
OSHA has used 70E in the reference to 110.16, Arc flash labels.. Did the employer fail to indentify the hazard.
