The EM lighting should not be switched. The NL might be switched according to customer's request(on a time clock for example).Originally posted by mrdiode:
...the night and emergency lighting being swicthed, do they need to be swicthed, can they be switched, please advise...
I think the emergency ballast can be switched. I agree with your opening statement:Originally posted by ryan_618:I better clarify. The power source for the emergency ballast cannot be switched, but the regular ballast can be.
For example, I am working on a small county jail project. Our lighting designer has egress lights and night lights in the sleeping areas. The night lights will be on forever. The egress lights in the dorms can be turned off at night. But there will be an auxiliary contact in the ATS, wired to override the on/off switch. Thus, if the utility power is lost, when the ATS transfers power to the generator all egress lights will come on.Originally posted by ryan_618: They can be switched, as long as they come on automatically when the power goes off.
I think it is a matter of energy conservation. There is no reason to require lights to be running 100% of time, even when the buildinging is completley unoccupied.Originally posted by infinity:
Well, it seems rather odd to me to have an area that is completely black when the normal power is present and then to have emergency lights illuminated when the normal power goes off as in a power failure. Why would those lights be needed during a power failure and not when some flipped off the light switch?
