reel-break
What code articals would cover this. Can you knock out a hole in a out door panel near the top on the side to join up with meter base hole.Someone says no unless its with a water tight hub? I was planning on a 2" male adapter and pvc?Guy says you can only use pre stamped hole knockout on a outdoor box is this new or I been mushroomed again?
