NJ Adopts 2020 NEC
goldstar
New Jersey
Electrical Contractor
NJ has adopted the 2022 NEC. The attached PDF is what the adoption looks like. Break out your pencils and erasers - you'll have to mark up your Code books. They don't make it easy :cool:
  • NJ Adopted NEC 2022-1.pdf
Actually it's the 2020 NEC not the 2022. Also that document has no adoption date or mention of the usual 6 month grace period.
My-Bad - you are correct, it's the 2020 NEC. Another brain fart - it's getting worse every day. :)
The 6 month grace period is typical for NJ. We'll have to specify which Code cycle we are filing permits under.
Looks like the A/C gfci provision made it through
And the GFCI exceptions for garages and basements went away
Also the outside disconnecting means for dwelling remained. I thought for sure that would have been deleted.
I think many fire depts. pushed for that section. Any firemen that I have spoken to will not pull the meter in the event of a fire not to mention that many meter pans are locked.
I wonder if that will be amended in the rehab code
Good question. I'm planning on installing a new service in my house and my plan was to pull the permit within the next 6 months under the 2017 to avoid the outside disconnect rule.
Its interesting to take a look at state amendments, I have a friend that has a NJ license.
I wonder what the reasoning for allowing romex in drop ceilings is ? [334.12(A)(2) being deleted]
Seems like 16 or 17 of the 36? amendments are all in article 425, must be a big industrial process heating lobby in NJ.
yes, seems like most of the regular 2020 code is in there.
I didnt realize NJ adopted the 2020 until today and was searching for the amendments and this popped up. Thank you for sharing.
