Don?ts
? Do not use edible oils such as Crisco as a gasket lubricant.
? Do not use petroleum or solvent-based sealants, lubricants, or fi re stop
materials.
? Do not install tape, insulated wire or cable in direct contact with CPVC.
? Do not use any glycol-based solutions as an anti-freeze.
? Do not mix glycerin and water solutions in contaminated containers.
? Do not use solvent cement that exceeds its shelf life or has become
discolored or jellied.
? Do not allow solvent cement to plug the sprinkler head orifi ce.
? Do not connect rigid metal couplers to CPVC grooved adapters.
? Do not thread, groove, or drill CPVC pipe.
? Do not use solvent cement near sources of heat, open fl ame, or when
smoking.
? Do not pressure test with air.
? Do not pressure test until recommended cure times are met.
? Do not use ratchet cutters below 50? F.
? Do not use CPVC pipe that has been stored outdoors, unprotected and
is faded in color.
? Do not allow threaded rod to come in contact with the pipe.
? Do not install Spears? FlameGuard? CPVC Fire Sprinkler Products in
cold weather without allowing for expansion.
