NM-B in SCH-80 RNC
snowroski
New member
Is it permissible by code to run NM-B through SCH-80 RNC in a residential application? I am unable to locate anything in the NEC to indicate yes or no.:-?
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I agree with Trevor unless it is outside or underground.
raider1
Logan, Utah
Agreed. If you have run the PVC under a slab on grade to an island or other item and the slab is in direct contact with the earth then the conduit would be considered in a wet location and you couldn't install NM-B.
I actually call this quite often on slab on grade homes in my area.
Chris
Dennis Alwon
Chapel Hill, NC
Chris
I got hit on that slab on grade years ago to an island. Had to run a UF homerun-:mad:
raider1
Logan, Utah
Yeah, I have had a lot of upset contractors when I tell them they must use UF for the slab on grade kitchen island.
Chris
