CuriousHomeInspector
- Little Rock, AR, USA
Is there a stated maximum distance that NM-B sheathing can extend into a panel/enclosure. I often see NEC 341.17(C) (outdated/moved I believe)cited as giving a minimum of 1/4" (although I thought this was for conduit and boxes, not panels). I have never seen a maximum listed in the NEC but I've had many claim that it is a 1/4" minimum, and anywhere from 1/2" to 1" maximum
Even the textbook references for home inspector education states that the sheathing should be cut far back to prevent adding fuel to a panel fire and to prevent build-up of heat in the wires (which I think is bunk).
Any insight to an actual maximum (within the realms of maintaining workability) and why with reference?
