jrc0109
- Orlando, FL
- Retired
Can No. 14 & 12 NM-B wire be installed above a drop ceiling without it being attached to the floor joists above the drop ceiling?
Thank you.
Thank you.
According to height of ceiling and distance from scuttle hole, we may need running boards in attic?I am on the field it’s not exposed. You could say the same thing about the wire in the attic.
Yes in some cases running boards are requiredAccording to height of ceiling and distance from scuttle hole, we may need running boards in attic?
