NM cable color identification
nizak
Is there any NEC code violation in using NM cable that is not current with the color scheme for identification?
I came across some "new" #10 that's been sitting in a guys closed up shop since the late 90's.
It's by no means ancient. I suspect it's from the mid 90's.
His wife said take whatever you can use. Several hundred ft of 10/2 and 10/3, new on spools.
Thanks
Thanks
No.
The jacket color thing came into being around 2000 and was conceived by cable manufacturers to make identification easier for the less than skilled/inspectors etc.
The jacket color is useful for identification but there is no NEC requirement to use a specific color of jacket on the NM cable. I think that we've just gotten used to looking at white, yellow, and orange to have a certain meaning.
Just check to see if it says nm-b. That would be the latest conductor THHN insulation rated for 90*c for use with most lighting fixtures. Otherwise earlier nm I believe had THW conductors for 75*c
Quite a few homes here have pink #12 NM instead of yellow. Don't know if I ever looked at the brand.
I started a thread about that after I saw pictures of it in a trade mag. Turns out a contractor in Las Vegas had it custom made and bought trailer loads of it when wiring tract houses. The reason was obvious - to discourage job site theft.
Thanks for that. No wonder I've never seen it anywhere else. And these were some pretty high-end tract homes in some gated communities. But tract homes none-the-less.
Around here, the meth-heads steal wire, throw it on a fire to burn off the insulation, and sell the copper for scrap. They don't care about the color. :)
