DaveBowden
- St Petersburg FL
Had an inspection today on a job with 4 new homeruns and a w/p panel on the back of the house. The panel has a 2" pvc sleeve from the hub on top of the panel into the soffit above the panel. The sleeve is less than 18" long. The panel backs up to the garage. I asked the inspector if he wold allow me to run the new NM runs thru the sleeve into the panel (I thought it should be UF cable but didn't want to install a junction box to change it over if I didn't have to. Firm believer in fewer is better when it comes to splices) or if I had to sleeve the NM inside the garage and enter the panel thru the back of it. His response was I could use the PVC but that I had to strip the NM right where it entered the sleeve. I always thought the jacket had to extend into the enclosure, but he said that only applied to junction and device boxes. He said it was a code requirement to strip the cable.
Not complaining about it because other than making sure I get the right neutrals on the AFI breakers it will make it easier to get my homeruns in the panel, but is he right? We are on the 2017 code here.
