310.8 (C)(3) Of a type listed for use in wet locations.
300.5 (C) Underground Cables Under Buildings. Underground cable installed under a building shall be in a raceway that is extended beyond the outside walls of the building.
300.5 (D) (4) Enclosure or Raceway Damage. Where the enclosure or raceway is subject to physical damage, the conductors shall be installed in rigid metal conduit, intermediate metal conduit, Schedule 80 rigid nonmetallic conduit, or equivalent.
(5) Listing. Cables and insulated conductors installed in enclosures or raceways in underground installations shall be listed for use in wet locations.
(H) Bushing. A bushing, or terminal fitting, with an integral bushed opening shall be used at the end of a conduit or other raceway that terminates underground where the conductors or cables emerge as a direct burial wiring method. A seal incorporating the physical protection characteristics of a bushing shall be permitted to be used in lieu of a bushing.
Maybe you missed that 300 applies to ALL wiring methods?Dave, nothing in what you posted indicates NM or UF can be installed in a raceway.
And maybe you missed some of Roger's post?300.1 Scope.
(A) All Wiring Installations. This article covers wiring methods for all wiring installations unless modified by other articles.
Roger said:
BTW, there is nothing in the 02 prohibiting it, if it were prohibited, note 9 in the Notes to Tables in Chapter 9 would be wasted ink.
all due respect, the xxx.22 sections actually say, "Cables shall be permitted to be installed where such use is not prohibited by the respective cable articles".Look at the sections Roger listed. The XXX.22 ones. "Cables shall be permitted to be installed where such use is permitted by the respective cable articles."
and maybe you should read mine little more clearly. :roll:Maybe you guys should read my posts a little more clearly? I stated in my second post that the 2005 has made the allowance for cables in raceways. My quote is from the 2002.
Rogeror, you can wait until jan 1 05 (if your area adopts it) and it being allowed is finally in specific wording.
See 342.22 thru 362.22 and 388.22
