mdshunk
- Right here.
Are there any prohibited wiring methods inside of fire rated assemblies? Namely, the fire walls between townhouse units.
I roughed an old townhouse that is being rennovated (total gut job), and did the device wiring in the common walls in NM cable. The job was inspected, and passed. A few days later, the inspector had a change of heart. The job was sort of "uninspected". Now I'm being told that the wiring in the fire walls between the units must be MC cable.
I'm not sure why he picked MC over AC, EMT, RMC or whatever. Is he right? Am I not permitted to use type NM cable inside fire walls? For completeness sake, there are no local modifications to the IRC or the NEC. Wiring within fire rated assemblies is not takled about in the "uses permitted" and "uses not permitted" sections of the wiring methods in the 300's of the NEC.
