I recently roughed in a new home in an area that I haven't worked in before.
I used the plastic nail on NM cable holders that per the Mfgr's literature state that up to 8 cables 14/2 12/2 14/3 can be secured.2 cables per slot are allowed, a piece of plastic separates the next " slot", 4 openings total.
My rough in failed due to the following.
The inspector will not allow the use of these on exterior walls where cellulose insulation will be installed because there is not adequate separation between the cables.
I have several 4 gang boxes that have 6-7 cables entering and are positioned in these stackers.
Is this anything that others have encountered?
