NM cables
George Stolz
Windsor, CO NEC: 2017
Service Manager
Depends on whether the staple in question is listed, and what the listing states that staple is capable of holding.
Typically, listed staples are limited to two cables.
I get around this by driving the staple sideways with no cable under it and using a zip tie.
George Stolz
Service Manager
I use these:
You are a very patient man. ;)
petersonra
Northern illinois
engineer
i'd be inclined to use a staple gun to set the tie to the stud.
do you trim the tie?
personally, i can't see any good reason to do so being as it is hidden inside a wall.
just out of curiousity, how many of you will admit to cutting holes in drywall and letting the scrap fall inside the stud cavity?
LarryFine
Henrico County, VA
Electrical Contractor
Because when I pull on the cable when I'm stripping out the boxes, the cables move. Drives me nuts. :)
Well, who told ya to wait until trim to strip the cables? :roll: Silly boy!
I strip, make up EGC's and groundeds, and make terminal pigtails and/or hooks at rough. All I need for trim is my electric screwdriver.
Saves time and keeps the freshly-painted walls a lot cleaner, too.
