In all the schools I've ever worked in I've never seen NM used, but that doesn't mean it can't be. Usually I see EMT used. Note that 334.12(2) limits much of the use in schools. Here is some of the applicable NEC text:
334.10 Uses Permitted. Type NM, Type NMC, and Type NMS
cables shall be permitted to be used in the following, except as
prohibited in 334.12:
(3) Other structures permitted to be of Types III, IV, and V
construction. Cables shall be concealed within walls,
floors, or ceilings that provide a thermal barrier of material
that has at least a 15-minute finish rating as identified
in listings of fire-rated assemblies.
(5) Types I and II construction where installed within raceways
permitted to be installed in Types I and II construction.
Informational Note No. 1: Types of building construction and
occupancy classifications are defined in NFPA 220 -2015, Standard
on Types of Building Construction, or the applicable building
code, or both.
Informational Note No. 2: See Informative Annex E for determination
of building types [NFPA 220, Table 3-1].
334.12 Uses Not Permitted.
(A) Types NM, NMC, and NMS. Types NM, NMC, and NMS
cables shall not be permitted as follows:
(1) In any dwelling or structure not specifically permitted in
334.10(1), (2), (3), and (5)
(2) Exposed within a dropped or suspended ceiling cavity in
other than one- and two-family and multifamily dwellings
(5) In theaters and similar locations, except where permitted
in 518.4(B)
