Designer69
Type R-2 occupancy. Dormitory bldg, split with sleeping rooms and individual dwelling units.
NM or MC wiring suggested?
Just curious, where did you get your answer?Never mind, I did some research and definitely MC.
through some older Mike Holt posts where the predominant position in the posts was to go with MC due to higher potential of damage to type NM and not a significant increase in cost by using MC.
This similar position was taken in other posts in other websites which I just googled.
For dry location indoor wiring?I live in Long Beach, NY and their local code states no mc in certaint applications due to corrosion from the salty environment. Best to check with your local AHJ.
The link states UF can be substituted or NM-C
Their spec sheet says otherwise.Southwire UF does not seem to carry that NM-C designation.
I don't know any sane person that would even think of wiring an entire dormitory building in UF. The rough in crew would think they were being punished for something...![]()
