jetlag
- Eatonton, Georgia
If I remember correctly you are only supposed to put 1 nm wire under a staple , I was looking at a new house in another county and they had some metal staples about 2 or 3 inches long. They had 5 or 6 nm #12 under same staples in the center of stud , I believe they nailed the staples in slightly first then threaded the nm thru the staples , that way they are stacked in neat. then when finished finished tighten the staple. Isnt that against code, I thought u had to use the stand off brackets for that. to keep the nm 1-1/4 " from edge of stud. Also they had 4 nm #12 s thru 1" hole in center of stud , I think my local inspector said only 2 in a hole, what is code on that
