winnie
- Springfield, MA, USA
- Electric motor research
This verges on a DIY question, and I will not be offended if a moderator closes the thread. In this case I am acting as a homeowner specifying work to be done. I am not asking for instructions on how to do this work.
I hold an 'aesthetic' opinion that metal armor cable is 'better' than NM. I am trying to figure out if this is illusory or if there is real benefit.
In my new (old) home, the earliest wiring uses AC cable, without a bonding strip. The armor itself is much more substantial than modern aluminum armor MC cable.
In a single family residence, where NM may be used, what (if any) would the benefits be to specifying MC cable? Would it make any sort of real difference in the performance or safety of the installation, or would it just add $$$ to any work done, without real benefit.
Does the thin aluminium 'armor' on 'MC-lite' provide any better protection for the conductors than the plastic on NM?
Is modern steel armor MC any tougher than the aluminium armor, or have they learned to make the steel very thin?
As best I can determine, the 'code' benefits are that MC cable could be used between a normal breaker and an AFCI receptacle (where AFCI is required), and that MC cable could be run across joists in an exposed basement without a running board.
Specifically asking the professionals: what do you do in your own home? Do you run EMT even though you are not in Chicago?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks
Jon
Thanks
Jon
