Would it be considered a damp location?
Is it pretty much an AHJ call when it comes to running NMB cable as opposed to UF cable in an unheated crawl space?
Thanks
I try not to run any more cables in a crawl space than I have to because of mice, squirrels and other varmints ( animal and human ).
I do the same but for a different reason... It is faster (eta: in new construction) to run the cables through the studs or the top plate, over to another device or the panel, and back down than it is to go into the crawl space.
Are you worried about the vermin chewing up your cable, or scaring you while you are down there?![]()
So if the "no varmints allowed" signs keep them out of the attic why doesn't it work in the crawl space? The non-literate ones tend to hang out on the lower levels or are they just rebels?If it really is damp down there you will have a bigger problem than the electrical cables. The floor joist (which are not pressure treated) will mold and rot and you would fall through the flooring.
I find crawling on rafters worse. The bad thing about crawl spaces is the rocks and construction debris that get you right on the knee bone.Actually I don't like to go into crawl spaces if I can help it. It's not a fear of vermin but bad knees. I wear good knee pads but I can still tell after going for a real crawl in a low crawl space.
So if the "no varmints allowed" signs keep them out of the attic why doesn't it work in the crawl space? The non-literate ones tend to hang out on the lower levels or are they just rebels?![]()
:thumbsup::thumbsup:If the crawl space is damp, they have bigger problems than nmb.
that is also a good point, these critters can bring you just as much or even more trouble as having the space be "damp".Your attic should be sealed so that squirrels have a real hard time gaining access and so should your crawl space.
I have seen plenty of crawl spaces where the access door was either broken or missing.
The you get cats and fleas. Not a nice place to have to crawl if they are out of control. Exterminate first then I'll come back.Your attic should be sealed so that squirrels have a real hard time gaining access and so should your crawl space.
Bats? What bats? I didn't see no bats!The worst thing you can get in an unsealed attic is a bat problems with bats living in the attic.
You can't just go in and remove or kill them because there are laws and serious fines for disturbing bats. So you have to hire certified bat removal service. This can run into many thousand of dollars.
