jetlag
- Eatonton, Georgia
I read the post on NMB to AC . There was a short pvc outside up to DISC switch. The replies were the NMB must terminate in box before leaving the house and continue on with thwn. My guestion is if NMB runs thru outside wall into back of a surface mounted WP fixture box is the wire considered outside and against code? What if the box is flush mounted, does that make it not outside. I guess we should run NMB to the switch and short piece UF to light?
