sfav8r
- San Francisco Bay Area
According to 334.15 all exposed work must comply with 334.15 (a)-(c).
334.15(c) requires that NMC running at an angle to the joists, if smaller that 2-6awg or 3-8awg, must be drilled and run through the joists or with running boards.
This seems simple enough, but my question is, what exactly is "exposed?"
In a crawl space that is 24", do you need to drill or can you staple to the joists? If this is permissible, does anyone have a code reference?
It also leaves me wondering when does a crawlspace become a basement? I just estimated a job that has about 4 feet of clearance.
Thanks.
Thanks.
