Is it permissible to supply an under-the-counter kitchen dishwasher (General Electric type Cafe) by poking a small hole in the drywall behind it and pulling through the hole a nmc cable and extending the cable on the floor on the underside of the dishwasher where the termination box is located?
The manufacturer did not provide a power supply cord and the instructions indicated a permanent wiring means, but did not elaborate. The dishwasher will be fastened in place and trimmed all around. The individual branch circuit will be protected with a lockable type circuit breaker. Is this the correct use of nmc cable and if not what section of code does it violate? What would be the correct wiring method if this isn't?
Thanks
Thanks
