I have a service call to replace a light on a deck.
I get there and the light is within the spa zone "no light"
I disable it and look for options.
What about low voltage? Anyone have a link for a lv wall sconce I can replace this with?
I was going to make a little nema3 box and gfi protect the line and then put a little led in the can and then some little led driven 12v sconce
Alternatlely I could try a segmented box at the switch and send a lovo switched line to thru the romex to the deck if I could separate it from the premise wiring.
(6) Low-Voltage Luminaires. Listed luminaires that don’t require grounding, and that meet the low-voltage contact limit, and supplied by listed transformers or power supplies that comply with 680.223(A)(2), can be less than 5 ft from the inside walls of the pool. } . transformers or power supplies that don’t exceed the low-voltage contact limit can be located less than 5 ft from the inside walls of the pool. Metal parts of the equipment must be bonded in accordance with 680.26(B); metal gas piping must be bonded in accordance with 250.140(B) and 250.26(B)(7). !lowvoltage spa lighting
from the commentary, it looks like any lovo garden light would do. the only thing is where to put the tx
