RAKocher
- SE Pennsylvania
How is the depth of the conduit confirmed with a trench-less install?
So there is a report to show the inspector or it depends on your equipment?Directly behind the cutting head of the directional drill is a transmitting sonde. The locator on top of the ground receives this pitch and roll information and is able to calculate the location of the cutting head. There is a continuous readout on the drill. Newer rigs have a computer program that will produce a finished plot of the bore. Older rigs have to plot the bore manually. But the depth can be calculated within an inch or so. A standard sonde is good to about 35 feet of depth. A high powered sonde is good to about 75 feet of depth.
i use a digitrack mark 3 system on my Vermeer 7-11 drill. I bought it used. Paid more for the locating system than I did for the drill itself.
I was asked to recommend a company to inspect an underground feeder installation that's about a 150' run, they're using a trench-less boring machine and I was curious how they'll confirm the depth. I was guessing that the machine logs some sort of a gps report of the install, but I'm just guessing and thought I would ask.
And he can only assume what it displayed is correct, and that you are using it properly.Just a random thought, we could run our locator over it when the inspector was on site, since it gives depth readings.
i've seen it verified when they hit an 12" fire main, 4' deep.
the water squirts up between the asphalt and the curbing,
all around the parking lot, as it floats the asphalt, and turns
the ground under it to mud.
it's a pretty clear indicator.
