stockexpert
Is it true that the NFPA does not allow a fuse or circuit breaker on the circuit that supplies the fire alarm control panel?
stockexpert said:Is it true that the NFPA does not allow a fuse or circuit breaker on the circuit that supplies the fire alarm control panel?
where is this code info found, all except the NEW JERSEY code. ??gadfly56 said:Circuit to be dedicated.
Not more than 20 amps.
Breaker colored red and labled.
In New Jersey, it has to be locked in the "on" position.
All of this is off the top of my head, so some details may be off.
You (or your source) may be thinking about fire pumps which kinda sorta operate that way. Overcurrent protection has to be at 3x the locked rotor current, which means if you jam the pump for any length of time, it's toast (literally).
gadfly56 said:Not more than 20 amps.
gadfly56 said:Breaker colored red and labled.
gadfly56 said:In New Jersey, it has to be locked in the "on" position..
iwire said:760.124, does not specify red breaker but that seems to be the standard way of meeting 'plainly visible'
Pierre C Belarge said:I can see it confusing some who identify emergency circuits red in color.
Pierre C Belarge said:.124 is not dealing with circuit identification, but the equipment that is supplying the low voltage side(PLFA),
iwire said:Your right, but I will not be able to sell that to the fire dept. :smile:
iwire said:Originally Posted by gadfly56
I can not find that one but it is required here in MA and RI as well.
gadfly56 said:NFPA 72 (2002)
4.4.1.4.2.2 Circuit disconnecting means shall have a red marking, shall be accessible only to authorized personnel, and shall be identified as ?FIRE ALARM CIRCUIT.?
As a side note, I have been assured by a member of the NFPA committee that is in charge of NFPA 72 that your installation can be failed if the label does not say, in all caps, exactly "FIRE ALARM CIRCUIT".
NFPA 72 (2002)
4.4.1.4.2.1 The dedicated branch circuit(s) and connections shall be mechanically protected.
