green2012
- highland park, il
The houses garage was wired with direct barial wire. Its 3 #12's. Hot-nuetral-ground. It comes out of the ground in a rigid nipple that punches through the garage. The prior owner rewired the ground wire to be a switch leg coming from the house. So now the garage is ungrounded. Its been like that for years. Home owner said he installed GFCI and they tripped instantly and wont reset. Whats the easiest fix? He wants to keep the switch set up. Ground rod?
