bjp_ne_elec
- Southern NH
Roughing in a remodel of a house and pull the panel cover to start tying in few circuits and notice the neutral is not isolated, after seeing a main disconnect out in the garage. Obviously I need to get this corrected, but my question is on the particular routing of the ground that I need to get from first disconnecting means to this panel. Does it have to be run along the SE or can I just take the best route? The 200 amp SE cable is buried in a few walls, and the only way to get the ground to run along with the SE is to rip Sheetrock down.
Thanks
Thanks
