918electrician
- Oklahoma
I have a pad mount transformer that I ran a 4 in conduit from to a 600 amp fusible disconnect to a 400 amp motor. There are parallel lugs for 300kcmil wire. The motor obviously does not need a neutral. Everything is 480v. My question is do I run the same size grounded conductor from the transformer to the disconnect? Also should it be Grey or Green? What about the wire from the disconnect to the motor?
