stickboy1375
- Litchfield, CT
I thought this was pretty funny. not my work by the way.
The stickers were weathered away. . .Does that mean GFI protection is not required.
The ground is down and the sign is up ... what's the matter with you? The sign is grounded ...I can't tell.... is that ground up or ground down?![]()
The ground is down and the sign is up ... what's the matter with you? The sign is grounded ...![]()
...what's the matter with you? The sign is grounded ...
No, it should be a W/P-in-use cover.Shouldn't it be a blank cover!![]()
No, it should be a W/P-in-use cover.![]()
Is it required to be a TR recep on an AFCI as well? :grin:
