hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
I have a Modine gas fired unit heater with a draft inducer blower. It makes a loud grinding or growling sound when running. I traced it as coming from the little 1/9 hp/3000 rpm draft inducer motor. I originally suspected bad bearings (sealed ball bearings) or a clogged up unbalanced blower wheel but on close examination I see that the motor is only noisy when power is applied. When it is shut off, noise stops immediately and it will coast smoothly for almost 30 seconds making absolutely no sound. You can see the shaft out front and cooling fan inside the motor through slots and see that the armature does not move backwards or forwards when powered or power is removed. There does not seem to be any lateral play.
This is a capacitor run motor and for giggles I'm going to replace the 4 uF cap and see what happens. Any other ideas?
-Hal
-Hal
