Buck Parrish
- NC & IN
I'm installing LED lights in the base board of halls and stairs. During the rough in we ran 14-2 in the walls. So now we have to drill a small hole to push the 14-2 through, make joints two 14-2's and the 16 coming from the Led's .
Then push all the wire, connectors and the LED back in the hole. The factory supplying the LED's has supplied a bit that is suppose to pop in to. They will be recessed.
Is it code compliant to leave these 24 volt joints in the wall with out a box? You would have to remove the molding to get to them.
Any inpiut would be appreciated. Thanks in advance.
