DRGREG
I recently saw a new multi meter that tests both amperage and voltage, on a wire, without contact. When I first saw this new meter I thought that the voltage testing was a real good idea. Then I started to think about what the meter would really be telling me, and the idea popped like a tick. It seems that the meter tests to an arbitrary ground or a lead can be used to connect to a different ground source. In a perfect world everything considered grounded would be bonded to the same source, but the larger problem is "who tests to ground"? Testing to a grounded conductor, or phase to phase, tells me important information, testing across a load or a switching device is uber important, but testing to ground is seldom needed. I guess that you could use this meter as an expensive volt-tic, but I am missing the the practical use for trouble shooting or testing.
